IPOD fitment to standard HU
Folks
Advice please if you would be so kind
2001 GTi, Standard HU and changer, also has a good Handsfree kit (Nokia) fitted. I want to run my lil ipod albeit's the new shuffle, now will it work? Can i keep the changer? Will the car phone kit be taking up the slot i need for the ipod..............please help!
Ta
Ta
I was searching the forums earlier and came across this thread:
http://www.tigerstyle.co.uk/poloforum/v ... t=xcarlink
From what I've read, you can apparently keep the CD changer.
More here: http://www.xcarlink.co.uk/
Anyone know anything about it?[/url]
Well, i havent ordered this for the following reasons..
I only have an IPOD Shuffle, bearing in mind this uses a 3.5mm jack or a 3.5mm jack to USB then there must be an alternative and cheaper cable to use for the shuffle.......if the gamma had preouts i could get a preout cable to a 3.5mm jack! grrr there must be something!
Alex, are these the old style preouts as in the ones that take phono leads? If so will this fit....and run a shuffle........
http://www.caraudiocentre.co.uk/product ... -22864.htm
The changer is usually superseeded, but there is a way that you can switch between the two92 rocks wrote:will the changer still run? & a link to ebay mate, infact if you are good with ICE installs Alex PM me ill detail in exchange for a sub and amp install with ipod fitment!
Im very good at ICE. Will pm you some details regarding this and maybe we can come to some sort of arrangement
Will link you when i have had a chance to browse!
