MK2 golf fittings
Discuss Suspension, Brakes, Wheels and Tyres
dubpolo
Sponsor
MK2 golf fittings
Post by dubpolo »
hello
i heard that things like brakes are the same fitting as the MK4 polo, does this mean a brake kit for te MK2 golfs will fit the polo????
chubbster
Post by chubbster »
this doesnt help at all but i heard that the floorplan of the golf2 is the same as the polo4
SundeepTT
Post by SundeepTT »
are you reffering to the brake disc size ?
standard Mk2 set up is 239mm (GTI 16v has 256mm)
and I think the mk4 poo is also 239mm ? is that right
if so there is a whole range of good drilled / grooved ventilated brakes out there to help the cause of stopping polo's :D
dubpolo
Sponsor
Post by dubpolo »
i was referring to brakes and weather a HI-SPEC kit for the MK 2 golf would fit???
