Link dead in sticky at top of page
Would really appreciate a copy
Anyone help?
Daz
9n Door Card Removal Pdf?
Mouse_GTI
I actually was fitting a new mirror to my sisters 9N last week, should of done a mini guide.
There are about 4 torq head screws at the bottom that need to be undone.
The rest of the door card sort of pops out of clips.
The door lock should slide out of the hole.
Take the front plate off the interior door handle and undo the two bolts within (the bottom one is quite long).
You will then have to unconnect the heated mirror and electric windows if you have them.
When putting back on, some of the clips in the door can only go back on one way. Take them off the door and put them on the actual door card before clipping them back in.
Hope that helps a little - was just off the top of my head
twobadmice
You have 4 t20 torx along the bottom of the door card
Behind the grab handel (one for pulling door closed) there are 2 t30 torx, the handel is just on two clips use something to pop it off but watch you dont damage it.
Then pull the doorcard off 7 clips and lift up wards to remove. Now remove the two electric connectors and the cable from the door release pull.
Hope this helps need anything else just ask
