drop links HELP???
polo51.4tdi
drop links HELP???
hey every1 iv got a polo 6n2 1.4 tdi and i would like to know if you need drop links to fit coil overs. also has any1 remapped or chipped the same car, if so has it worked ok and the cluch hasent slipped or owt. thanks
Re: drop links HELP???
Ok first things first, please use english - its well hard to understand text language!polo51.4tdi wrote:hey every1 iv got a polo 6n2 1.4 tdi and i would like to know if you need drop links to fit coil overs. also has any1 remapped or chipped the same car, if so has it worked ok and the cluch hasent slipped or owt. thanks
You dont need drop links to fit coilies - you just need to use the original top mounts from your old suspension.
Alot of people have chipped/remapped the 1.4 TDI. Being a 3cyl engine, its not a huge increase, but youll see almost 100bhp or more out of it which is quite a pleasant jump.
Clutch appears to be ok on most, but as always, more power leads to quicker wear of components.
