Lol not one bit!3LL1077 wrote:Haha so you admit you LOVE LC3K then?
>>>>Wallace's MK5 6N2 SDI Progress Thread<<
adamwallace1989
HA HA
Even i didnt no What SDI means lol. did a tiny little mod this weekend decided to debadge the boot. i also tried looking for the flasher relay to do a little mod but just cant find it anywhere lol
This is all i could find
adamwallace1989
Well!!!
After i had finished cleaning it last night it was a bit dark so i will take some when i get home after work.
Dont suppose any one can help me find the flasher relay? Does it even have one? i found the connection in the harness just not the relay lol.
adamwallace1989
Relay 19??
i though relay 19 was for the wipers also which one is for the fog lights?
Subtle Changes
adamwallace1989
Flasher Relay
when you pull your high beam stalk forward it sends a signal to this relay to allow the live to pass through.
- Tim_GTi
- Post Whore
Re: Flasher Relay
Take it your trying to get your fogs to flash with your Full beams also?adamwallace1989 wrote:when you pull your high beam stalk forward it sends a signal to this relay to allow the live to pass through.
I'd love some info on this, once you've done it if you could run me through a step by step that would be great
adamwallace1989
(Flash + Fogs) :)
bang on mate been looking at doing this for a while. trying to do this without an extra relay tho. all you do is put a diode across from the signal going into the flasher relay to the signal for the fog light relay. i just cant find the relays lol.
soon as i have done it ill put up a guide
adamwallace1989
Not Sure
i would say you could, my first thoughts would be just to but a switch on to stop the current going to the full beam. i might go down the scrap yard n get some kind of wiring harness to do all this. saves cutting the wires in my car
