Fitting FK Angel Eyes, two questions.....
lolhoward
Post by lolhoward »
I have just received my Angel Eyes this morning but looking at the so called manual i'm not sure where one connection goes. You've got the two harnesses that connect lights to car body, then two to battery then two wires from one light and one from the other which meet at a connection which says ''to the relay''. Where does this connection go. Also on one side you have a a grey & red wire, the other just a grey. Does it matter which side has two or can it be either. Please get back to me as want to fit 2moro! :wink:
Here's a pic if i've confused you :?
Josh_polo
Post by Josh_polo »
Looks simple enough to me, just copy the diagrame.
lolhoward
Post by lolhoward »
Yeah helpful josh! :lol:
What/where is the relay. What does it connect too?
3LL1077
Post by 3LL1077 »
Isn't it a straight swap Howard? Wires etc i mean
Torq-Al
Post by Torq-Al »
Without trying to sound too simplistic..........
Have you had a look at the connectors etc. already on the car? would of thought it was a plug & play job! :?
Instructions always seem to make it sound worse! :lol:
DanOliver
Post by DanOliver »
Surely that "To the Relay" plug would go to the relays behind the dash that control the headlights already there? So when you switch the headlight switch, the relay activates the two?
As others have said.. it should surely just be a straight swap??
lolhoward
Post by lolhoward »
Yeah the rest is plug and play just cant find where to place that relay connector. Did think behind the fuse box. Suppose i'll have to take that apart now.
Currently got bumper off, lights partially on, wired in, dipped and main beams work just not sidelights (angel eyes). As said above the relay needs to tell them to come on.
Any body know where the relay is for sidelights or how to get to it????
DanOliver
Post by DanOliver »
Have you checked a Haynes manual?
lolhoward
Post by lolhoward »
Sorry haven't got one :roll:
DanOliver
Post by DanOliver »
You have a 1.4 don't you? Mines no good then I don't think.. I have the 1.0... Maybe Elliott?
lolhoward
Post by lolhoward »
Doing a quick google. Could it be an additional relay that I plug onto the connector.
Like the one on this thread. http://www.clubpolo.co.uk/forum/index.p ... =111470&hl
lolhoward
Post by lolhoward »
Right, sorted. Got rid of the cable connecting the two and the battery and works fine. Just need 20 286 bulbs now! So bumber will be back on tomorrow and then back off once my bulbs arrive :evil:
Cheers guys
3LL1077
Post by 3LL1077 »
I have a Haynes Manual but i have no idea where i put it. I try things out myself :D
Alex is my portable Haynes if i need any technical jargon :P
lolhoward
Post by lolhoward »
worked for me! :lol:
lolhoward
Post by lolhoward »
............eventually
