IS YOUR POLO CUTTING OUT , PLEASE READ,
Josh_polo
Post by Josh_polo »
We on about the hose sized pipe that connects underneath or the part that has the valve that opens when you rev?
vw-po-low
Post by vw-po-low »
[quote="Josh_polo"]We on about the hose sized pipe that connects underneath or the part that has the valve that opens when you rev?[/quote
The hose from your crankcase to your Air Box.
Josh_polo
Post by Josh_polo »
:? :? Im not good with terms :lol:
The hose sized one?
kyle1b1
Post by kyle1b1 »
the pipe thats to the left of the throttle body that connects to under the airbox
Josh_polo
Post by Josh_polo »
kyle1b1 wrote:the pipe thats to the left of the throttle body that connects to under the airbox
I know the one now, will try this at the weekend. Still dont know why my accelerator is stiff :cry:
kyle1b1
Post by kyle1b1 »
also when you get the airbox off you will see where the cable attaches to the throttle body with a turner thing which is obviously spring loaded get plenty of wd40 on that and work it.
and also check in the footwell make sure it aint stiff where the pedal attaches and not the cable of TB
