Apr R1 DV
oliverpologti
Apr R1 DV
Post by oliverpologti »
im thinking of getting the apr dv just want anyones thoughts on it
is it any better than the forge one?
and with the recerc dv do you not hear any noise
looks like a quality piece of kit though
whitegtipolo
Post by whitegtipolo »
It prob just as good as the 007p forge valve, but i preffere the forge item as the APR has a diaphragm like the standard bosch item, and i had a forge splitter too but the 007p is the best by far when fitted the correct way round!
more-bhp
Post by more-bhp »
Forge item is a lovely looking piece of kit - just open the box when it arrives and you'll get excited..
and it fits perfectly... without fuss....
remove airbox and put cone filter on and you hear some dumping...
DO NOT BE TEMPTED to fit "dump to atmos" for more noise - the car will not work properly...
whitegtipolo
i know i tried dump to atmos and was ok till you got on the mway then limp mode!!!
flyfs6
Post by flyfs6 »
I got mine at the time because it didn't need servicing etc and no one else was using one. From what I have heard it responds quicker than the Forge item...probably only marginal.
Jeff GTi
Post by Jeff GTi »
i run the apr r1 valve and can confirm that it reacts noticably faster, and the fit and forget technology makes it a winner too, its also smaller than the forge one and has cured my boost surge issues of on off on off feeling in acceleration from low revs when giving it some
this was because the piston was unable to hold the boost firmly and kept opening slightly, making me lose boost then have to build it back up, the diaphram valve only loses boost and dumps when you let off acceleration, not in between
it also aids faster boost correction, so if you let off then need to put your toe back in, you dont get lag, just good hard boost straight away again
defo an advantage item over the forge piece having tried both, and looks more classy too i think
