Failed MOT today headlight question
avfcnutter
Post by avfcnutter »
My 1.4 mpi failed its MOT today :( for 2 things, tyes (new they were low anyway) and then headlights being wobbly inside so when driving the lights themsleves move around, searched it on here to find a couple of you have experienced the same thing. Is there a repair for this or am i going to need new headlights? If so wheres the cheapest place to get the new ones from? looked at KMS £72 each :(
James
lolhoward
Post by lolhoward »
I had this. Not sure if they mooved whilst driving but did wobble a bit. The clips inside were broken so had to be replaced. I paid £120 for a pair brand new from a local VW shop.
lolhoward
Post by lolhoward »
Also if you knew the tyre's would fail, how comes you didn't get them replaced before hand?
avfcnutter
i checked them and they were low but not as low as the illegal indicator, but they were illegal on the inside due to the tracking :(
lolhoward
Post by lolhoward »
oh I see. Unlucky mate. I had the same years ago on my old Mk4. Needed two new fronts as the tracking was out!
avfcnutter
anoyying isn't it, but i had it tracked like 8000 miles ago :S
alexperkins
Site Admin
Post by alexperkins »
This headlight issue is a common one. Both sides on my old one went at different times. It was due to the plastic used in manufacture for the adjusters. As time went by, due to what its made of, it becomes very fragile and even the slightest little tap or move will shatter it, rendering the headlight loose and requiring replacement.
Newer ones are replaced with a 'pink' nylon over white, which doesnt become fragile with age
avfcnutter
yeh i had a search and found a few people had experienced the same thing, poor design from VW. :cry:
DanOliver
Post by DanOliver »
I think thats happened to mine.. though the MOT is not due yet..
the actual reflectors inside move from side to side when I take the back cover off..
avfcnutter
yep, so when they try and adjust where ur lights point on the m.o.t, it doesnt work. installed my astrum lights today, omg what a pharce. one of the height adjusters wouldnt work, something wrong with the wiring, so had to wire it up with the old lights wiring. and was just such a pig job, the lights are in now tho, would say the astrums arent as well as the riginals, and they dont fit quite as perfect as the old ones either, nothing major at all tho, look good and i think its worth saving £30 a light.
alexperkins
Site Admin
Note that Hellas are a must if you use HID bulbs to ensure a crisper beam :)
DanOliver
Post by DanOliver »
Ooo.. I better bear that in mind then :P
