in the passenger footwell pull all the carpet up and the sound proffing and what have you and will be a gromit under their with a single cable going through and is easy to get to and see from under the bonnet.
peice of p***
From memory, once you've got the thin plastic surround unclipped from the head unit then the slots to put the removal keys will be easy to see either side, when I took mine out it needed a 'yank' to come free once I'd released it.L'enfant terrible wrote:Thanks Kyle.
One more question (that I nearly forgot...)...
How the **** do you remove the standard sony radio?? It's the one that came with the car with the cassette player etc... I think that the plastic edge round the perimeter (that's usually removable) is fixed onto it and I can't see anywhere to put the little metal hook things down (my knowledge of correct terminology is terrible...).
Also will this fit in it easily? I had to get a fitter to put it in my pug as I couldn't get the bugger to fit!
http://caraudiosecurity.com/shop/produc ... oogle.html
