9n2 lowered.
9n2 lowered.
Does anyone have any pictures of there 9n2 lowered?
I REALLY cant decide if I should do it or not.
Any advice?
Any advice?
- Tim_GTi
- Post Whore
There are absolutely loads of pics on here mate, have a search around, starting with here:
http://www.tigerstyle.co.uk/poloforum/v ... hp?t=33182
I'd definitely look at lowering your car. It's highly improves the handling and looks of your car.
wrongranson90 wrote: And apparently coil overs make your comfort level drop below par.
correctly set up damping rate and rebound rate coilovers will be better for handling than normal shock and spring setups
my eibach coilovers are also comfier than other springs only and shock and spring setups iv had in the past, such as spax, koni fsd's with eibach springs etc
its all in the quality of the product, not the type of product
- whitegtipolo
b4
after
springs are good but with coilovers you can mess changing your style slammed one month higher few months later, springs i often found left me disappointed with coilovers you get em just as you want! From experience cheap coilovers are as good as £700 ones for road use, so unless you plan on racing on a track dont waste £100s on dear set up believe me! I got TA Technics and they just as good as KWs i had on my astra!
after
with my default alloys. which are 14" or 15" maybe im not sure... i think i'de prefer coilovers, the ability to smack the front down or just the back down or pop it back up when i want seems good. Know of any good brands or cheap but good brands I can look out for?
plus with coilovers you can drop til you shop.
As whitegtipolo said TA Technics ones off ebay
http://cgi.ebay.co.uk/HighQuality-Coilo ... dZViewItem
- whitegtipolo
