Now
Soon to be..hopefully
Im sorry but that is total cack!whitegtipolo wrote:dont remove helper springs will fail mot and you may aswell have no suspension will be running on bump stops now its dangerous!
So according to this the fact that the inner diameter at the seat of the spring is ~2mm larger than the suspension strut shaft it locates itself correctly when lowered to the ground = no failMOT Regulations wrote:Shortened or lowered coil springs
Take care when jacking vehicles with shortened or lowered springs fitted. Provided the spring ends locate correctly when the vehicle is lowered into the normal running position, without assistance this is not a reason for rejection.
