[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 can bus adapter - Page 2 - UK-POLOS.NET - THE VW Polo Forum
its the ign live you need and an illumination, ign i got from ciggy lighter but turns the stereo off wen the ign goes off not the key removed, and illumination from ciggy light bulb, if you want it to go off when you remove the key you would have to find a feed off something that goes off when you pull the key? i couldnt be bothered looking?
looking at the diagram it goes to switched live (ie ignition live) so you can feed it from the switch on the column or anywhere else that has a switched live
the ciggy lighter live is a switched live but , there are two switched lives one when you turn the key back and one when you remove the key its silly!!
Jeff GTi wrote:you know hoe yours is wired up white polo, what happens if say the bulb goes in your cig lighter, does your HU lose its display?
also have you fused the live and illumination feeds?
dont suppose you can provide photos of how you have done it can you, really dont want to be beaten by a flaming radio
the ciggy is fused anyway so that causes no problems but you can add another if you want and its not the main feed its the ignition live so no major current! Also the illuminaton is for when you turn on ya lights, so some stereos go dimmer or brighter or dont change ! ill have a look tomo as im off and take some piccys 4 ya
