I have a Polo 6N2 1.4 SE 60bhp, 2000 X reg in Crayon Red (the best colour
All well and good, until I decide to stop faffing around scraping it, stop being a tight arse
Here's the thing... I've got the (less than) helpful owners manual out, and it says I have four fuses in this little fuse box on top of the battery. Correct up until this point. I should have two 30A fuses for the ABS motor relay and ABS main relay, a 20A for cooler 1 level, and a 10A for the compressor.
However, I've got one 30A, one 20A and two 10A fitted in there which straight away I know is not right, and the fuse I pull and scrape to correct the ABS fault is a 20A yellow one
I also have no idea which fuse relates to which function because the manual doesn't state what order these fuses should be in
So, could I ask anyone to please post up a quick photo or clear description of what fuse should be fitted in which holder, and also which holder relates to which component?
Cheers for any help you can give.
Best regards,
Dave
