But since cleaning the throttle body it has been ok until today. The idling seems to have gone even worse.. and the car is now over reving when still and making a gasping noise ... idling at about 2000rpm and going down to about 1700 and then back up again. Keeps repeating the same process over n over .
I have also been told that if you remove the battery from the car for at least 3hrs it should reset the ECU and should calm the problem. Now i have done that hoping that it will cure the over reving but it hasnt ..
any1 know what i can do next ?? PLEASE HELP ME
