quick question lads?
clarkson
Post by clarkson »
the standard mk5 lights the all red ones, can someone explain where the lights are, as in is the brake lights at the top then normal lighjts and fog
Tim_GTi
Post Whore
Post by Tim_GTi »
Haven't driven my car in a while, but IIRC its:
bottom for normal,
bottom and top for brake,
bottom middle for reverse/fog
top middle for indication.
h4r1s
Location: Leicester/Sheffield Drives: Polo MKV-6N2 1.4SE 16v 75BHP
Post by h4r1s »
Top = Brakelight
next section down = indcators
next section down = sidelights
bottom = reverse/fog
:wink:
Tim_GTi
Post Whore
Post by Tim_GTi »
Ah there you go, I'm not around my car enough these days!!
clarkson
Post by clarkson »
great help lads thanks!!
one more though do u still have to switch the wires around like it ses on the mk5 light diy guide or is it plug and play??
vw-po-low
Post by vw-po-low »
If your putting them onto a 6n then yes.
N/S lamp
Swap wires 1 and 2
O/S lamp
Swap wires 4 and 5 and then cut the notches off the plug so you can turn it around. then plug and play.
clarkson
Post by clarkson »
cheers, did it yesterday looks so much better
