[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 how to remove front VW badge - UK-POLOS.NET - THE VW Polo Forum
To remove the full badge just twist it 30 degrees to the left and it should pull out mate. The badge is pretty much held in the same as the H7 bulbs are if u have ever removed them. Then get a knife and carefully pry the silver bagde off
yeah took me a while to get mine off to fit chewys painted 9n badge
(which by the way is a different clip on system if anyone was thinking about putting a 9n one on its the same badge but doesn't clip on unless you have hot glue and a stanley)
but yes if you take the grill out
4 torks looking down over when u lift the bonnet
pull the grill out
and just turn it round .u can see how it works kinda
