The tyre popped off and the rim now has a bad dent. To get home (3 miles) i put the space saver on. The car drove in a straight line but i did notice that the steering wheel had shifted around 20 degrees to the left.
I've had a look underneath and the n/s wishbone is bent. It looks as though they are designed to do that because it's bent next to one of the holes that are in it. This morning my partner was leaving to take the car to the local garage and noticed that the steering wheel height adjuster lock isn't working properly. It sort of holds the column but if you push down on the wheel, you can get it to give up the grip. Not ideal.
So my questions are;
Is the wishbone designed to bend in order to protect other components?
Does the bent wishbone and space saver wheel explain the steering wheel moving 20 degrees off center?
Is the steering lock problem a 'safety feature'?
Can i expect any other components to have suffered?
Any help or advice is gladly appreciated.
