Anyway, had a browse thro the i/net and it seems the answer is my N294 valve that is opening/closing my DV quickly becos of overboosting. Has anyone else experinced this? Only reason i can think its overboosting is from exhaust still to be upgraded. Think I mite sick on the OEM N75 boost valve too for now.
N294 Valve
- KennyPOLO_Gti
- Platinum Member
N294 Valve
When I am driving my car aggresively I get the feeling of the boost goin "off" and "on" quickly and cos the car to have a rocking feel to it. Everyone thats in my car when it does it can feel it happening and most of them dont know the 1st thing about cars so its not my imagination!
- KennyPOLO_Gti
- Platinum Member
- whitegtipolo
oliverpologti
- whitegtipolo
easy no performance gains just stops ecu opening the DV valve and when it does operate its direct from manifold pressure so quicker and louder dump!
1.
Remove the engine cover you will see two sensors on the rocker cover one on the left and one in the middle! This is the n249 the middle one! You will notice that one pipe goes to the DV valve the other from the t-piece!Basically you loop the vac pipes on the valve together using the pipe from the t-piece the small one!
2.
Then you take the longer piece and run it fron the t-piece direct to the DV
sorted so now you get instant dump when you lift the throttle and the ecu cant dump boost on a slight spike!
1.
2.
- KennyPOLO_Gti
- Platinum Member
- KennyPOLO_Gti
- Platinum Member
- whitegtipolo
no your car has other ways to kill boost if it exceeds the desired level, this mod just stops it dumping tiny amounts of pressure causing surges and on off boost! If it exceeds too much it shuts the throttle plate and opens the turbo waste gate!!
Kenny what have you done to make your car better with your stage 2???
- KennyPOLO_Gti
- Platinum Member
oliverpologti
- KennyPOLO_Gti
- Platinum Member
oliverpologti
