Brakes
Re: Brakes
Depends what you want.... Looks or performance...
the 280mm brake setup looks better but does not give you a vast improvement over the standard setup.....and it costs a lot!
Standard disks with a decent set of pads would be the easiest improvement...unless you wanted to fit some 2/4 pot callipers (Brembo stylie).... That WOULD be expensive....
Braided hoses might make a tiny improvement... but (MAKE SURE THEY ARE PLASTIC COATED!) If you have exposed braid on a road car you end up with grit in the braid which grinds its way though the hose inside....
Re: Brakes
they would be for performance. Dont think the standard setup would be too good when iv upped the power in the car
- chrisjames
Re: Brakes
Maybe just some drilled disks mate,
I was looking at these:
http://www.venommotorsport.com/manufact ... o%20Mk%205
combine them with some quality pads and it should be good enough. 280mm would look a lot better though
jamie1.8tpologti
Re: Brakes
get some 4 pots like me
Re: Brakes
Where did you get yours from?
jamie1.8tpologti
Re: Brakes
i got mine fitted when i had 20vt put in down tsr
- chrisjames
Re: Brakes
^ Any pics?
Re: Brakes
Don't suppose you know the spec of the calipers etc?
I just don't fancy paying TSR prices
Id rather price it separately and try get it cheaper
Re: Brakes
is this the 4 pot you have fitted?
Golf 1 280/24mm Billet 4 - Black £580
jamie1.8tpologti
Re: Brakes
high spec four pots in black wit 280mm discs pics on my thread
- Tim_GTi
- Post Whore
Re: Brakes
jamie1.8tpologti wrote:high spec four pots in black wit 280mm discs pics on my thread
