amyone had any problems with their headlights before?
main beams are not coming on on both headlights both happened at exactly the same time as soon as i turned them on tonight
sidelights still work as norm
full beam still works as normal
fogs still work as normal
just cant get main beams on
just dont seem likely that both bulbs go at exactly the same time anyone got any other ideas ?
going to phone vw in morning just wanteed to know if there has been any problems with anyone elses headlights
an help appreciated
cheers
ollie
headlight problems
oliverpologti
Re: headlight problems
have you checked the bulbs, or the fuse for the dip beams, could have been a power surge thats blown the bulbs or fuse
oliverpologti
not had time to check yet i will do when i get back from work it was pitch black when they went so had no joy there last night couldnt see a thing
oliverpologti
checked fuses and they are all alright
not had time to chack bulbs i am very doubtfull it is the bulbs as they came on then driverside went out so i turned lights off and on and then no lights at all
anyone any ideas?
anyone any ideas?
- charlievwp
If not fuses, then start with the cheapest....bulbs.
If not, then the switch?
How old is the car oliverpologti ?
oliverpologti
its a 56 plate gti
