Forge Intercooler on "v good!"
Re: yup yup forge on tuesday!!
Its not all about BOOST.... but More-BHP Stage 2 will run 17-18PSI for as long as the turbo can produce it.... the K03s are too small to make big boost in the higher RPM... by doing it you run outside of the turbos efficiency.... which in turn then makes less power not more.
Mandatory required hardware Spec for this is FMIC, TIP, Uprated Air Filter, Full Turbo back exhaust.
J
J
- whitegtipolo
Had my intercooler fit today at forge and all i can say is WOW!!! what a difference it has made to the power delivery especially on the mway !!! i got nearly 10mpg more on the way back !! it seems to pull alot harder than it used to when it hits 4000rpm!! Ill post pics when its cleaned etc! chose red logo and red hoses, they even threw in the map to throttle hose too! all fitted for £465 managed to knock another £10 off it LOL! Only the tip to get next!
- KennyPOLO_Gti
- Platinum Member
Cant say am not VERY jealous!!!!
Get some pics up to rub it in!
- whitegtipolo
will do lol
hey i been like that for a long time i cant believe what i got ! I defiantly advise someone to fit eg awsome or forge as its a pig to do! got plans for my center lower grille will be done end of next week!!!
- KennyPOLO_Gti
- Platinum Member
Re: Forge Intercooler on "v good!"
How long did it take them???
- whitegtipolo
bout 5 hours because of taking photos each stage!
- Tim_GTi
- Post Whore
Awesome mate! Bet your over the moon. Sounds good, red pipes n logo on a white car
- whitegtipolo
some quick pics !
halfway through modifyin the centre grille so its just a gloss black surround should be ready end of next week!!
- Tim_GTi
- Post Whore
Awesome! I think it would look better with the OEM grill though. Are you trimming it so the surround just covers the fix points?
- whitegtipolo
this is my grille in progress will be all smooth and gloss black to slot back in to finish it off nice!!
- whitegtipolo
yup yup!!!Tim_GTi wrote:Awesome! I think it would look better with the OEM grill though. Are you trimming it so the surround just covers the fix points?
- KennyPOLO_Gti
- Platinum Member
Looks the sex mate!! Am soooooo jealous! Just need to get my exhaust done first then splash out and get one! Just need to find someone up here that will be able to fit it correctly!
- Tim_GTi
- Post Whore
Ah thought as much. Will look good!
Freelance Badger
KennyPOLO_Gti wrote:Looks the sex mate!! Am soooooo jealous! Just need to get my exhaust done first then splash out and get one! Just need to find someone up here that will be able to fit it correctly!
Just wait until the feature is published and then just follow my instructions and photos.....
- KennyPOLO_Gti
- Platinum Member
Is it getting published in a mag or something for the i/net???
