Suspension on 6n2 1.4 16v
Discuss Suspension, Brakes, Wheels and Tyres
r_penny23
Post by r_penny23 »
Hi all,
I want to drop my car a bit as it looks like an off-roader. Its on the 1.4 16v standard alloys and I still want it to be practical, so how low can I go? Does know of anywhere in the South West that could do this and also supply the parts, Im on a bit of a budget but I dont want the ride to be total s**t!
polopowah
Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
Post by polopowah »
on standard alloys you can go as low as you want!
-60 or more, but obviously your gonna compensate the ride comfort going that low
fitting suspension on your own aint too hard, you just need a good tool kit, and sumwhere dry to work in.
low is good :)
-Ben-
carmadaaron
Post by carmadaaron »
i think -60mm looks the neatest! 8) more than that youre likely to suffer a sore back! :lol:
r_penny23
Post by r_penny23 »
Chears for the advice :D , do you think I could get away with just springs or will I have to go for coilovers? :?
carmadaaron
i think if u go for over -60mm you will need shortened shocks. any lower, get some coilovers. :D
polopowah
Post by polopowah »
yeah you need full coil-overs going any more than -50mm, im currently at -75mm all-round, but if your on a budget i'd opt for -40 springs
lowering the car lots dont come cheap :shock:
-Ben-
carmadaaron
springs are around £60 per set.
coilovers are £££. you got coilovers polopowah? looks 8)
Aaron
polopowah
Post by polopowah »
yep got coil-overs
im currently on spax rsx at -75mm all round and they cost me 570 quid
-Ben-
r_penny23
Post by r_penny23 »
looks like it will be springs for now then, I havnt really got 570 notes burning a hole at the moment, are eibach the ones I should go for?
polopowah
Post by polopowah »
Eibachs are very good for comfort, so i've heard
go for them!!
-Ben-
carmadaaron
yeah, i heard they are good too! :D
r_penny23
Post by r_penny23 »
the eibachs it is then, the only ones Ive seen are 30mm lowering springs any ideas on where it get 40mm?
wul3er
Post by wul3er »
can someone tell me were you get a set of lowering spring for £60 everywere near were i stay is £100+ for a 40mm drop
Also will the 1.4 8v be the same or could this be why mines are a bit more expensive
carmadaaron
where abouts u in scotland. glasgow's Drivers offers good priced parts!
polo2k
Post by polo2k »
i think the spring rates on the 8 and the 16v are different
if you want some of the eibach quality and also a mix of koni dampers the kw are the way to go as they use eibach, blistein, and koni goodness
highly recomendeed by my self and mr speedy
