Is it an easy job?
From pics I can see that the frontpipe connects to the manifold with a square 4 bolt flange - do you access the nuts/bolts from underneath or under bonnet?
Is the gasket reuseable with a clean/exhaust gum - metal gasket?
Does the rear of the front pipe just slip into the rear section with a clamp and exhaust gum?
Oxygen sensor is still fitted to the 2nd hand cat - I'm hoping they haven't just cut the wires, are there connectors near to the cat somewhere?
Any troublesome covers need removing to get access?
Any rusty exhaust hanger clamps or is it just a rubber hanger?
Anyone have any pics to help me talk him through it?
Thanks in advance, seems to be a very helpful forum and bunch over here
