Still not sure if its the revised one or not
Bushes
Re: Bushes
cheers guys
Re: Bushes
Got it mansmithysmoo wrote:Think the part number is in the links I put up above...
Part No 6LL407183
Re: Bushes
If you are really stuck, I'd offer two ways to work this out:- 1) look for a "splash" of paint on your ARB, my wife's original factory -fit one had a white splash of paint on it. The replacement one did not have any splash of paint on it - but maybe that is not conclusive on a sample of one - but I think ETOS does mention "white" for that option of ARB. 2) get yourself a smallish magnet, then try to get it to attach itself to the endstop ring of the ARB - not the ARB itself just the ring beside the clamping points. If it sticks to it then its a newer version with steel end-stop rings - if it does not then its the original older style ARB with plastic end-stops.blkpolo wrote:cheers guys![]()
