New member here, so hi everyone. My daughter is now the owner of a 2000 1.4 16v Polo and I have the job of making sure everything is up to scratch
Any way one of the problems is the rear washer, I have read through a number of posts and it seems like a common problem, I have checked the normal things where it goes but I do have a question, when I press the washer in by the steering wheel I do not hear the water pump but the rear washer wipe works, now when I use the front washer the pump works and the jet sprays out water, so any ideas?
Another issue I have which may have been related in a way, is the luggage compartment light, I have checked it has a 12 feed which it does, but it doesn't get a ground when the boot opens, am I right in thinking that the boot latch holds a relay which is probably broken here, looks like it had a soaking some time in the past?
Vondoogle
