throttle body
tompeters
throttle body
Post by tompeters »
need a guide on how to remove and clean the throttle body if anyone can help please.
Tim_GTi
Post Whore
Re: throttle body
Post by Tim_GTi »
You don't need to remove it to clean it. You can if you want, but that's up to you.
To clean it without removal:
Purchase some carb cleaner from halfords.
Remove your air box
Spray some cleaner on a rag and wipe the throttle body until visably clean.
Get some to start the engine up and rev it up to around 4-5k, pulsing the pedal. As the butterfly flap opens spray the carb cleaner continuously into the TB. Use around a quarter to third of the can.
Keeping the car running, take it for a good spin after to burn off excess cleaner.
tompeters
Re: throttle body
Post by tompeters »
thanks mate try it
tompeters
Re: throttle body
Post by tompeters »
just done this now it were horrible all black so wiped it clean then sprayed carb cleaner in. seems to be running better thanks for this pal
NFS
Re: throttle body
Post by NFS »
Remove the breather hose as this is what leaks the oil into the throttle body, and attach a breather filter which you can buy from halfords. If you leave the breather hose connected all your hard work will go down the drain as the throttle body will go all black again with dirty oil in a matter of days!!!
tompeters
Re: throttle body
Post by tompeters »
cheers for that will do is it the pipe on the left hand side as you look from the top at back?
NFS
Re: throttle body
Post by NFS »
yh the small pipe that goes in on the left side of the airbox.
tompeters
Re: throttle body
Post by tompeters »
cheers i no which you mean. what do i ask for at halfords? not very good wit cars lol
Tim_GTi
Post Whore
Re: throttle body
Post by Tim_GTi »
Just a breather filter. You need the specific size though, I'm not sure what it is on yours, it's 25mm on the GTi though,
stuart1903
Re: throttle body
Post by stuart1903 »
Can someone tell me exactly what this breather filter does? I have similar problem with Oil in the air cleaner and the source of this is the breather pipe.
