Hi, my clutch pedal is squeaking... and I don't want the above to happen!Pedal Box! Same fault as Caddy's etc. Clutch goes stiff, doesn't get changed in time, puts strain on Cable and twists/breaks/cracks pedal box mounting bracket that's bolted to the bulkhead.
Any idea how to fix it? Is it a job for the WD40? If so, what do I need to grease/remove/destroy/whatever!
Thanks.
