I have just bought a 6n2 5 door. It has central locking but I naturally wanna make it remote cntral locking. The problem (i think) is it has neumatic (works on suckion apparently) where can i get a system that`ll work. Link if possible please
Thanks guys.
Remote central locking???
braindeadhmster
Re: Remote central locking???
Alright mate,
Theres several different kits that you can buy, there fairly cheap around £30 i think, possibly less.
All you do is buy the kit and then its literally a plug in and play the one i went for was by "Rightclick"
I have two sets of flip out keys with little vw logos on!
The central locking pump is in the boot, on the drivers side tucked behind the carpet on the wall!
hope that helps!
hope that helps!
braindeadhmster
Thanks alot Joe I got one, I`m thinking of connecting it to the lock/unlock button on the drivers door card.
The drivers door wiring isnt suitable for wiring the CL kit into. Safest place is wiring it directly onto the pump, as there is a permanent live going into it.
braindeadhmster
With it being numatic (air operated) if i wire it to the pump will it still work? I presume the pump is the little box in side of my boot.
considering I wired one up to a 6n polo a month ago with factory CL, im 99.999% sure
All remote CL kits have different wiring configurations on them for negative, positive, pneumatic, and trigger wiring systems, as different cars use different systems, so youll be fine
And yes its the black box on the drivers side
braindeadhmster
Whre do i connect everything? Indicaters, live, cl motor ect. Wire colors if poss. Thanks for all help.
