Headlight washers
turkpolo
Headlight washers
Post by turkpolo »
the headlight washers aint working after i tried to get the bumper off wich i couldnt after 3 hours!
can you suggest what can i do abt this matter??
6n2si
Re: Headlight washers
Post by 6n2si »
Sounds stupid but is your washer fluid level above a half? They don't work below that level. Also your headlights need to be on 8)
turkpolo
Post by turkpolo »
lol i know headlights have to be on, i also know that there is a sensor in the washer fluid but where is the washerfluid in the engine bay :?
alexperkins
Site Admin
Post by alexperkins »
Right hand side mate. Blue cap with the windscreen on it
Also check to ensure that the fuse for the washers hasnt blown.
turkpolo
Post by turkpolo »
never thought abt the fuse cheers mate lol but wich fuse :?
alexperkins
Site Admin
Ummm i think its in the 40s. ill just check the haynes....
47. 3rd line down on the right hand side.
turkpolo
Post by turkpolo »
thanks :D first thing in the morning
emma_88
Drives: 6N2 Polo GTi & 9N3 Polo GTi
Post by emma_88 »
Ha, I never knew fluid level had to be above half for the washers to work!! Thought mine were a bit dodgy - But all is sound now lol
Tim_GTi
Post Whore
Post by Tim_GTi »
Fluid level must be above 1L, not half way. Considering you didn't know where the fluid was I'm assumin you haven't filled it up before, which would make me assume it's just low level. So try filling it up first.
turkpolo
Post by turkpolo »
true say tim. well its been only 3 months i bought the car soo
Tim_GTi
Post Whore
Post by Tim_GTi »
Yeh I'd definitely put it down to low fluid then. Check that first. Will save you alot of time!
turkpolo
Post by turkpolo »
cheers tim :)
