GTI Inlet Manifold & Throttle Fitted - 1 Small Problem
Ok, finally fitted the GTI inlet manifold and throttle body onto my 1.4 16v polo. Everything is working, the car accelerates etc. However the car is now finding it difficult to idle as the revs jump up n down the 1000 mark. Using my VAG COM i have one fault code that comes up:
- Barometeric / Manifold Pressure Signals: Implausible correlation P1553
I have used the channel 60 to do the adaptation run on the throttle body but no luck. Anyone have a clue what the error means and what can be the possible fault.
Cheers.
Cheers.
Re: GTI Inlet Manifold & Throttle Fitted - 1 Small Problem
that would be due to the fact its not designed for the engine. from memory its dueo to too much air going in.
ill check elsa when im home and tell you the official word on that error, but theres a chance it cant be fixed as they are somewhat different engines with two different management systems
Is the fault definitely due to too much air entering? If it is, is it possible to cure the problem by mapping the ecu to let it no that it has a bigger throttle body etc?
im not sure. ill check elsa and let you know
Do you think you can also check if the GTI and 1.4 16v MAP sensors are the same, as i havent changed that.alexperkins wrote:im not sure. ill check elsa and let you know
Where does it connect to?
Also, I need the fault code number for that error - what youve given isnt enough for elsa to translate
The one that goes on the side of the intake manifold. I dont no if its MAF or MAP
Ermm..i believe it was 17961alexperkins wrote:Where does it connect to?
right...will have a look
What engine code is your engine? And what engine code did the manifold come from?
m9 is AUA n dont no what engine code the manifold came off i got the product code which is 036 129 711
You got the two letters after the 711? If you have MSN pm me lol itll be easier on there! lol
Letters are BJ and ive pm'd u my msn
