What do 'Top Mounts' do??
i have a set of coilovers and people suggest to change the top mounts what do they do and where can i get them from cheers
Re: What do 'Top Mounts' do??
The top mounts are the bits that connect the top of the struts and/or dampers to the chassis. They are usually rubber things so that a high level of decoupling of road noise and shock from the chassis of the car. Also at the front they tend to have a bearing assembly to make turning the steering parts easier and quieter.
Pratikt wrote:i have a set of coilovers and people suggest to change the top mounts what do they do and where can i get them from cheers
You can get the from the dealer or euro car parts do them for £10.50 each
umm how many should i get then 4 or 2 =S
I am just changing the two front ones on mine, only because two of the bolts don't tighten up after fitting the strut brace
In the first instance, I'd only buy the two for the front and buy the bearings that sits below them - the rear ones, if needing to be changed, are a lot easier to change after fitting the suspension than the front ones are. Also buy in some bolts and nuts for that job.Pratikt wrote:umm how many should i get then 4 or 2 =S
i c i c thanks wil order them soon, which bolts n nuts do i need.??
The three bolts securing the top mount on each side + the nyloc nut at the end of the strut rod + maybe the same sized three bolts at the end of the TCA/ lower swivel + drive shaft nut + claming bolt and nut - same both sides apart from the drive shaft nut as only one should be needed.
can i get all of these from euro car parts. if someone could post me a link to the bolts etc would be uite helpfull thanks
I'd cut ECP out of the loop on this one and head straight for a VW, Seat or Skoda dealer's parts place.Pratikt wrote:can i get all of these from euro car parts. if someone could post me a link to the bolts etc would be uite helpfull thanks
umm i c i c so im guessing al the parts are just standard replacements??
du i hve to get all of those parts or are some kind of optional??
I think that you should buy all these parts to stay safe!
