Discs??
whitegtipolo
Discs??
Post by whitegtipolo »
will audi tt mk1 150 solid rear discs fit my polo?? all the dimentions are the same but it is listing it as a quattro will this effect the size?? Ive heard the pads are the same weather vented or not?? :P As i have 312mm fronts but 232mm rears so these look like they will fit my package??
http://cgi.ebay.co.uk/AUDI-TT-QUATTRO-1 ... m153.l1262
whitegtipolo
Re: Discs??
any ideas??
Re: Discs??
Not a definative answer, but I've got a 4WD Passat and I think that the rear discs are different to the 2WD cars. Why not look at a disc brake manufacturer's website like ATE or Bembro and see if the TT 2WD rear discs are the same as the TT 4WD rear discs?
whitegtipolo
Re: Discs??
i ordered them after doing some research and the rears are wrong, i needed 232mmx9mm and these are 239x9mm b0ll0cks!!!!!!!!!!!! didnt notice they were a few mm out!!!!!!!!!!! :oops:
Re: Discs??
whitegtipolo wrote:i ordered them after doing some research and the rears are wrong, i needed 232mmx9mm and these are 239x9mm b0ll0cks!!!!!!!!!!!! didnt notice they were a few mm out!!!!!!!!!!! :oops:
Have you had a look to see what other people are fitting as an upgrade. BTW the parameters that full define a brake disc are:- 1) overall diameter 2) thickness 3) height 4) bore 5) PCD and number of wheel fixings - and maybe one other thing like "top hat diameter. Using bigger discs is okay as long as you get the correct caliper mounting brackets, remember this will always end up, in normal use, being an expensive cosmetic upgrade as the rear of these cars is so light that the original rear brakes rust up due to under use - so bigger ones will mess up even sooner I'd think. My wife's Polo's rear brakes stay clear of rust but that is due to her driving on hilly country roads - it seems that on flat roads and in town rusting rear discs is what you get this these cars.
Running Monkey
Re: Discs??
Post by Running Monkey »
I would have to agree with this. I've just bought a 2006 1.4 FSI Sport and although it's only got 7k on the clock, the rear discs are rusted to hell. I might have to change them .... no, I think I am defo going to have to change them. Any suggestions as to the best place? Are the Febi discs any good?
RM
