A friend has had an alteration in his Polo GTI and needs the following a.s.a.p
Bonnet - Preferably almost definatley has to be Metallic black.
Front bumper - Again in black
N/S/F (Left hand ) Wing - Again preferably black.
N/S/F Foglamp
N/S/F Indicator
Steering rack - hopefully it might just need a tie/track rod its too dark to see at the moment but somethings definatley moved
Possibly a lower control arm (Although i'm guessing this is same as standard polo?)
N/S/F Headlight - Needs to be complete, I have managed to source almost everything above only problem is most of its the other side of the country but if push comes to shove i'll have to go and fetch it but I am really struggling getting a headlamp.
Cash waiting.
*EDIT* Sorry forgot to say its a 51 plate Mk5 GTI, 3door (not that that matters) in Metallic black.
GTI bits required ASAP!
Re: GTI bits required ASAP!
Good evening all,
Managed to get the car stripped today and its sadly worse than I thought, rear gearbox mount has sheared but sadly its broken it right off the box itself anyway heres a bit of an updated want list.
N/S/F Foglamp
N/S/F Indicator
N/S/F Headlight (HID's, Xenon)
Steering rack or n/s Tie rod
Now for the new bits,
N/S/F WIshbone/control arm complete with ball joint (can anyone tell me if there the same as standard 6n2 polos?)
N/S Driveshaft (Same as above, can I get away with using standard 6n2)
Gearbox
Antiroll bar
Bonnet catch assembly
Ta,
N/S/F Foglamp
N/S/F Indicator
Gearbox
Antiroll bar
Ta,
BUMP,
Anybody
Anybody
My weekly bump, have now sorted most parts and car start putting the car back together, but there are still a few outstanding if anyone can help.
Front bumper - SORTED
N/S/F (Left hand) Wing. - SORTED
N/S/F Headlight (HID's, Xenon) - SORTED!! WHAT A JOB TO FIND.
Steering rack or n/s Tie rod - SORTED
N/S/F WIshbone - SORTED
N/S Driveshaft - NOT NEEDED
Gearbox - CRACK WELDED (BY A KIND SOLE IN WORK), RESEALED AND REBUILT BY ME!
Antiroll bar - NOT NEEDED
N/S (dont think that matters) - Headlight washer complete wth top (bit that shows on the bumper).
Bonnet with hinges (must be Genuine)
N/S Front bumper guide/clip
N/S/F Foglamp
Ta,
N/S/F Indicator
N/S/F Foglamp
Ta,
N/S/F Indicator
