New Owner... a few questions
Re: New Owner... a few questions
Two bolts under the clips. You then need to pull off the pipe on the left handside, then pull the cover upwards - it will be firm as there is a tight rubber gasket that surround the throttle body.
Thank you Alex I'll have another look.
On page 7 of the VW Radio Beta instructions it says
“It is possible to switch off the traffic announcements permanently by exiting the TP mode”
But omits to mention what exiting the TP mode means. Can anyone tell me which buttons to press to turn off the traffic news permanently?
Ray
Ray
It seems pressing the FM button while in normal mode turns off the traffic news. The small TP stays in the corner of the screen but the larger TP text below disappears.
Ray
Ray
iirc you Press and hold the TP button Ray, cant remember off top of my head
With regard to the top cover on the 1.0 litre engine...as Alex pointed out... there are only the two bolts under the round clips holding it on. It is located by two pegs at the back but these just pull out. There are three pipes in total to remove, one at the left side and two at the right.
Ray
Ray
Does anyone know what the actuator /solenoid/relay sound is when you open the driver’s door?
Ray
Ray
hi yeh its just the fuel pump priming the injectors,
also another common problem is the f...... gearboxes, there made of plastic and whine like buggery, thats why im now selling up, bout 500-700 for recon
Thanks for that Paul, another mystery solvedpaulzpolo wrote:
...its just the fuel pump priming the injectors...
Ray
Could someone remind me how to post a picture and the size it needs to be to appear in the post rather than a link?
Thank you
Ray
Thank you
Ray
- Tim_GTi
- Post Whore
Sign up to Photobucket & create an account.RayD wrote:Could someone remind me how to post a picture and the size it needs to be to appear in the post rather than a link?
Thank you
Ray
Then upload your pictures.
Once uploaded, copy the link (found under the designated picture on Photobucket) that starts with a [img],%20and%20ends%20in%20a[/img].
Paste this link into the reply box on here.
Sorted.
Thanks Tim.
