Coilovers on with pics
- whitegtipolo
Re: Coilovers on with pics
kenny does your front end catch on the arch bolts i slammed mine today removed the adjusters at the rear whichis fine but the front tyre rubbs ?? i could go alot lower at the front LOL!
ill put some more pics on my topic
looking sexy kenny
nice work!
- Tim_GTi
- Post Whore
Kenny were these AP coilovers? if so I need to pick your brain!
tried fitting the AP kit on my mates yesterday, the rear mounts didnt fit the springs without flipping the springs upside down and taking the adjustors out, and the front springs weren't big enough to sit on the front mounts properly.
I was fairly sure they were the complete wrong kit, but a phone call to venom apparently stated 'it's the same kit throught the 9N and 9N3'.
i assume you got yours fitted elsewhere. did they say anything about having troubles fitting the front srpings with the top mounts? or do you have any pictures of the kit prior to fitting?
cheers
cheers
- KennyPOLO_Gti
- Platinum Member
Hmmm sounds like the kit maybe wrong mate? The springs fitted without any troubles at all to the mounts at the front, took the guys no time at all. Took more time removing and fitting the new bushes! Same for the rears, i removed the adjuster totally as it sat too high, but the spring fited now problem mate, the flat of the spring sat at the bottom if ya know what i mean??? Sounds like AP have got them mixed up if you are having problems with them both? My kit was the Polo 9N as they are all the same chassis.
- KennyPOLO_Gti
- Platinum Member
Just noticed this post Chris, yeah they scrub like ****, i raised them a bit the other day and they only scrub when goin "fast" and hit a bump in the road, which is a lot with our roads! Need to raise them a touch more before i get the tracking done tomorrow which am not happy aboutwhitegtipolo wrote:kenny does your front end catch on the arch bolts i slammed mine today removed the adjusters at the rear whichis fine but the front tyre rubbs ?? i could go alot lower at the front LOL!ill put some more pics on my topic
get some 195x40x17 tyres on them and wind them back down
i have just dropped mine more this morning, now have some lovely nose down action compared to the back of 1/4 of an inch
just enough i think, just need to get the bbs's back on now after they are balanced and tracking re done
- Tim_GTi
- Post Whore
Cheers for that kenny, i know what you mean with the rears, we had to mount them upside down so they'd fit the mounts! not good. And the fronts werent having it at all.
my mate phoned them yesterday and also sent picture evidence. Venom said they'll pass it onto AP for a response, and if it's inconclusive they'll just exchange the kit! happy days
- KennyPOLO_Gti
- Platinum Member
Am just going out to have another look, see if i can do anything to reduce the scrubbing, failing that just need to put them up a tad. Just put new tyres on this week, wish i knew 195's would of went on, must be well stretched!!!
Tim - yeah sounds like you'll get a new kit, your mate must be raging!
- Tim_GTi
- Post Whore
ah you have no idea mate haha. should be sorted soon though!
- whitegtipolo
send me a pic tim as they are the same design as my weitecs, you must note that gti spec ones are different to other 9n polos as the front strut is larger so if its a tdi you are fitting them too you need the gti spec kit!! I know this from fitting standard 9n coilovers to my gti b4 and had to add a metal sleeve to them as they were too skinny for the hubs on the front!
- whitegtipolo
i have solved the rubbing problem by removing the front screws from the arch liner and folding the metal flap in and also the arches pull out a bit by hand but dont pull too hard!!KennyPOLO_Gti wrote:Am just going out to have another look, see if i can do anything to reduce the scrubbing, failing that just need to put them up a tad. Just put new tyres on this week, wish i knew 195's would of went on, must be well stretched!!!
- Tim_GTi
- Post Whore
Can't believe how thin the front wings are on the 9N3, I'd love to be able to roll my own arches haha.
Chris were fitting them to a 1.2. I'll get hold of the pic for you. But basically the front spring was too small in diameter to sit on the top mount properly!
whitegtipolo wrote:send me a pic tim as they are the same design as my weitecs, you must note that gti spec ones are different to other 9n polos as the front strut is larger so if its a tdi you are fitting them too you need the gti spec kit!! I know this from fitting standard 9n coilovers to my gti b4 and had to add a metal sleeve to them as they were too skinny for the hubs on the front!
Here is a picture of the problem... Nightmare!
Any suggestions/thoughts appriciated!
- whitegtipolo
i know it sounds silly but is the spring the correct way up?? also on my last coilovers it had a top hat for the spring and it sat in the centre of the bearing if ya get me??!!
but if they are the correct way they are wrong !! kenny has the correct part number as he has the same ones!
- Tim_GTi
- Post Whore
Yep they're the right way up, as the other side is flat for the adjustor to sit on. We did try flipping them for the hell of it anyway, also didn't fit!
