ANYONE ELSE HAD SAME PROBLEM???
last night i was driving normally and all of a sudden i hear a loud thud/bang noise....i pull up and see if there is anything i can see underneath the car. all seems fine....today morning i drive my car and the coolant light comes on. i check the coolant and its well below its minimum. i filled up the coolant....but i think its more serious as i can hear a loud noise when i drive. you only hear it sometimes...i read somewhere it might me the water pump? anyone got idea of something else it might be? any advice would be helpful.
- KennyPOLO_Gti
- Platinum Member
Re: ANYONE ELSE HAD SAME PROBLEM???
Is your car still under warrenty???
nah mate it aint...if it was i would have taken it straight to them....it was out of warranty 6 months back.KennyPOLO_Gti wrote:Is your car still under warrenty???
Sounds like the water pump.nomi_7860 wrote:i read somewhere it might me the water pump?
If it is then you are well looking at a shocking bill as waterpumps ain't cheap as far as I know.
polo1.9TDI SPORT
- Drives: Polo 1.9 Tdi Sport
You have a coolant light!!!
WTF, My car was below the line and i have had no warnin lights, how low does it have to get?
Dave
Dave
polo1.9TDI SPORT wrote:You have a coolant light!!!
Dave
mate my level was well below the minimum. its all fixed now.
Tell ya what tho!.. something similar happend to me yesterday. I was driving along at normal pace when i heard a a bit of a clatter sounded like something fell off my car!... Couldnt figure out what had happened at the time... Now, my windscreen is misting up loads and i can smell coolant... no fault light on or anything and the coolant level has dropped a little?.. What the hells going on!?!? lol.
Well, for the interest of others, what was the root cause of your problem and what was done to fix it?nomi_7860 wrote:polo1.9TDI SPORT wrote:You have a coolant light!!!
Dave
that sounds like a heat exchanger problemaj2day wrote:Tell ya what tho!.. something similar happend to me yesterday. I was driving along at normal pace when i heard a a bit of a clatter sounded like something fell off my car!... Couldnt figure out what had happened at the time... Now, my windscreen is misting up loads and i can smell coolant... no fault light on or anything and the coolant level has dropped a little?.. What the hells going on!?!? lol.
i THOUGHT the problem was fixed but there was another problem....i had to get the radiator replaced, fan relay and some other bits and the bill came to around £492.00
i hope aj2day you aint got the same problem man.
OK, this is a different cause of shaking but I have a problem with my VW Polo (year 53). I always use unleaded petrol but in a moment of madness, well, it was a long queue at the other pumps, I had used Shell V-Power instead. After a few days, I'm now finding the engine is vibrating and jumping and the gas exhaust warning light comes on in the dashboard. The engine dies if I don't rev but I can't understand why my Polo cannot cope with Shell V-Power with RON 99. I guess I'll have to take it to a garage to drain the Shell V-Power. What a waste of time and fuel! Can anyone suggest a better solution? Thanks in advance!
Keep topping the tank up with normal unleaded - itll be fine after the balance sorts itself out. Some cars dont like 99 ron for some reason - its really odd!
Can't see why rough idle would be down to using super fuel...I would hazard a guess you've got a CAT or camshaft related problem IMHO.
