I've got a strange vibration on my MKIV when the revs are around the 2500 mark, especially if the revs drop down e.g. when changing gear. At first I thought the exhaust was loose, it's that kind of noise. Although I've had that checked out, and appartently it's fine... It feels like the vibration/noise is almost right under the drivers seat (possibly?)
Also, sometimes, well most of the time, when I go to start the car it doesn't attempt to start, it just makes a horrible noise, abit like "errrrrrrrrrrrrrrrrrr" (sorry). It's a constant noise, not changing in tempo or tone.
Does any bright spark have a clue what these might be?
I also need a cambelt change, thermostat change, and temp sender change. In Bristol if anyone has any recommendations.
I'm sorry for all the questions
