The radiator gets warmish in the top corner by the top hose, but the rest stays cold. What is the best way to test the radiator for blockages.
The car has had this fault intermitantly for about the last 15,000 miles (intermitant in that it looses a lot of water, the hose and rad always stay cold). But has just got worse again which I am guessing is due to the fact its summer again and im not using the heaters, thus not removing any heat from the system.
People have said its the head gasket, i find this hard to believe as it does not explain the the cold rad and hose. And i also think it would have gone altogether after 15k. There are also none of the tell tale signs of head gasket failur ie water and oil mix. Or steam from the exhaust.
My thaughts are that the coolant (or water as i cant afford to keep putting coolant in
I know i have wrote a lot but ive tried to give as much detail as i can. Thanks in advance for any help.
