Protection Light
Discuss In Car Entertainment
stuart1903
Protection Light
Post by stuart1903 »
Installed my subs, amp and 6x9s finally after a bit of a wait after a small accident... ran them until wednesday till they didn't work on the way home from work and the protection light is on. Fiddled about with the cables and the ground cable seems to be the problem. regrounded it and changed the ring terminal but its still not working. Any ideas.
Tim_GTi
Post Whore
Re: Protection Light
Post by Tim_GTi »
what protection light? on your amp?
Checked all the fuses?
stuart1903
Yep. Works sometimes when I move about the ground cable but not for very long.
Tim_GTi
Post Whore
Post by Tim_GTi »
sounds like a bad ground to start with. where it is located to and how it is secured?
stuart1903
Tim_GTi wrote:sounds like a bad ground to start with. where it is located to and how it is secured?
Secured onto the screw which holds the black plastic trim next to the parcel shelf on, been sanded down to the bare metal and attached with a ring terminal which I've changed. Checked all the attachments to the amp so any more ideas.
Tim_GTi
Post Whore
Post by Tim_GTi »
could be the amp throwing up a fuss. have you got another one you could test in it's place to rule out the wiring? or a mates perhaps?
stuart1903
Tim_GTi wrote:could be the amp throwing up a fuss. have you got another one you could test in it's place to rule out the wiring? or a mates perhaps?
Another AMP you mean? Not really no.
alexperkins
Site Admin
Post by alexperkins »
Try grounding it on the factory ground point behind the passenger side shelf at the back. Its a proper mount too, and should be pukka if its a grounding issue.
