Bolts Needed
luke_poloe
Bolts Needed
Post by luke_poloe »
I need to replace a few bolts, firstly I need the two nuts and bolts that hold the suspension strut onto the hub carrier and the two hex bolts that hold the brake calliper, does anyone know if these are the same on the 6n and 6n2?
Gary Gee
Re: Bolts Needed
Post by Gary Gee »
luke_poloe wrote:I need to replace a few bolts, firstly I need the two nuts and bolts that hold the suspension strut onto the hub carrier and the two hex bolts that hold the brake calliper, does anyone know if these are the same on the 6n and 6n2?
caliper ones are am sure.... i took some out of 6n's for mine altho am sure the bolts are only 36p each for the caliper bolts from VW brand new ...
luke_poloe
Re: Bolts Needed
Cheers m8, i will try VW today
