What 1.8t
- revolutionrock
What 1.8t
Need some advice on what 1.8t to use and what gearbox???
Frome a passat 2003?
Re: What 1.8t
You'd stuggle with a Passat engine, as its longitudenally mounted in the car. A golf engine is transverse & what u'd want. Too many brackets, hoses, manifold etc to find if you got a Passat engine.
Re: What 1.8t
What car do you have?
- revolutionrock
Re: What 1.8t
You can get a passat engien that is horizontal mounted.... The car is a 6n2Torq-Al wrote:You'd stuggle with a Passat engine, as its longitudenally mounted in the car. A golf engine is transverse & what u'd want. Too many brackets, hoses, manifold etc to find if you got a Passat engine.
Re: What 1.8t
An old shape s3 or tt.
Look for a bam engine code
- Tim_GTi
- Post Whore
Re: What 1.8t
Aye, the BAM engine is the most power to come out of the factory.
- revolutionrock
Re: What 1.8t
There is a seat whit a 1.8t? am I right? Any other models?
- Tim_GTi
- Post Whore
Re: What 1.8t
yep, mark 3 ibiza cuprarevolutionrock wrote:There is a seat whit a 1.8t? am I right? Any other models?
Re: What 1.8t
And the Leon. (180bhp). BAM engine is the audi TT engine. (225bhp)Tim_GTi wrote:yep, mark 3 ibiza cuprarevolutionrock wrote:There is a seat whit a 1.8t? am I right? Any other models?
- revolutionrock
Re: What 1.8t
How have they done whit the drive shafts? make new?i think the easiest way would be to make new ones?
Re: What 1.8t
Just found some info that will make your life easy! Use an Ibiza Cupra gearbox & driveshafts for ease of transplant.revolutionrock wrote:How have they done whit the drive shafts? make new?i think the easiest way would be to make new ones?
Then you'll need to make custom engine mounts to enable you to put your choice of 1.8T in.
Apparently if you go on club-polo & search for ash's polo you'll find some useful info.
- revolutionrock
Re: What 1.8t
How wide is the axle track on a ibiza?Torq-Al wrote:Just found some info that will make your life easy! Use an Ibiza Cupra gearbox & driveshafts for ease of transplant.revolutionrock wrote:How have they done whit the drive shafts? make new?i think the easiest way would be to make new ones?
(Im gona googel it )
Re: What 1.8t
Should be same as a Polo, think it's same floorpan, or very close!?revolutionrock wrote:How wide is the axle track on a ibiza?Torq-Al wrote:Just found some info that will make your life easy! Use an Ibiza Cupra gearbox & driveshafts for ease of transplant.revolutionrock wrote:How have they done whit the drive shafts? make new?i think the easiest way would be to make new ones?
- revolutionrock
Re: What 1.8t
I'm really interested to know more about drive shaft, I have look on a golf mk4 gearbox.
make new drive shafts is expensive!
Any one know/or have done it, how did you do whit the drive shafts?
