Now then guys n gals, got a problem with electric windows the drivers control won't allow the window to go up or down and won't let the passnger side go down the passenger control will work up and down and from the drivers control I can put the passenger window up only!
Any ideas , new drivers side control unit ??
Electric windows help
Re: Electric windows help
right'o just got home from work and had a play taking door card off, when u trying to put window up and down you can here a clicking noise, but still no movememnt, but i swapped over the connections, so the left side going to right and the right to the left and now from the drivers side control unit the passenger window will go up and down were as before it would only go up !
but still nothing with the drivers
any one got any idea's just the control unit, the motor? dono if it is the motor cos the passenger side works, ??
help lol
help lol
No one got any ideas? Fuses are fine no visible fault!
it'll be the switch jason
got one on order
right'o it isnt the switch so looks like the bloody motor !
alhought the passenger window is working fine now, jus required a new switch!!
has any one got a mk5 drivers side electric window motor and reg for sale??????
