Whats peoples thoughts on the best out there, need some that give good balance between vocals and bass.
they are 6.5" , if you're gonna get components its gonna be a pain coz u have to send wires back and forth through the doors for the tweeters, so i reccomend get some coaxial speakers and if u wanna amp them, connect the wire from the amp to the factory wire near the head unit which goes to the coaxial speaker. Ive always recommended coaxials in polos, even in my own. and if u want extra treble, change the tweeter in the door pod near the window and connect the wire to the coaxial speaker as it has 2 terminals.samm wrote:Right, i need some new door speakers, cant be bothered to take the door panel off for no reason, so what size door speakers will be a direct replacement, is it 6.5" and how do you get these wired up and if i get a system with tweeters, how hard are these to get hooked up, any modification need to be made to the piller mount etc.
I would iamgine so, as DINs have to be a generic size. Can't be 100% though.samm wrote:
Are the golf mk 4 and 6n2 same fittment for the cubby hole?
how are the original vw components wired on the 6n2? i know on the 6n cable went from headunit -> tweeter -> midTim_GTi wrote:Running components is no issue at all. I'd definitely recommend them over coxials.
Just mount your crossovers behind the doorcards and there's no fuss.
