![Very Happy :D](./images/smilies/icon_biggrin.gif)
just wondering if theres anything i need to know before i go hacking away lol u know how instruction manuals are! any fitting tips etc...
cheers
Jacko
The Silicon Hose Kam Racing normally supply are 5mm to wide in terms of diameter and a lot larger than they should be hence having to cut them. Your best bet is to use the correct BMC 90 degree bend (SAC - 09070).Kam Racing wrote:you'll need a sharp blade like a stanley knife to cut down the 90 degree silicon hose slightly. If you don't the cda will get in the way of the bonnet shutting or at least thats what I found when doing mine.
you can see how I put everything together in this pic:
Yeah it is far too big. You can get the proper BMC 90degree bend pipes from Venom Motorsport and Demon Tweeks.jacko_b_23 wrote:yeah i had a look at the weekend and realised the silicone hose supplied was way too high and even with the reducers it didnt seem to fit round the throttle body properly?
where can i get that proper bmc hose from if u know?
cheers, jack
No problem at all Jack,jacko_b_23 wrote:thats brilliant thanks a lot mate. think i will order the proper pipe as i dont really fancy chopping away
that brackets massive too lol did guess it would need cutting. and thanks for the advice on cleaning the throttle body. think i saw a DIY guide on how to go about it on here so ill use that.
shame it wont get done til a couple weeks time, would have been cool to have it done for ed38 and trax...im more than happy to just have it tho after being on the hunt for months!!
jack
