I only got the car 2days ago it had a service and full mot before it was given to me and the dealer i got it from is trying to say they dont think the clutch isnt included in the warranty.. But ive got to speak to the bloke who sold me the car.. Im telling them f*****g straight fix that s**t! lol!
My Clutch Is Making A Noise!
Everytime i push down the clutch pedal it seems to be making a squeeking noise like a spring is squeeky? Has anyone got any ideas? Sounds like its coming from the engine not the pedal itself..
- Whos Adam?
Re: My Clutch Is Making A Noise!
My clutch squeaks a little when pedal is pressed, I presume its just parts moving, not causing a problem
How loud is it?
How loud is it?
My clutch pedal was squeaky once aswell but it didnt sound like the engine as you say. I told the mechanic when in for sevice and he greased it up and that solved it
Ahh Ok Maybe Its A Common Problem Then..? I Can See What It Is.. Its A Little Black Pipe Attached to Some Metal Rod That Is Attached To The Bottom Of The Car.. If That Makes Any Sense.. I Think It Has The Clutch Fluid In Maybe?Whos Adam? wrote:My clutch squeaks a little when pedal is pressed, I presume its just parts moving, not causing a problem
How loud is it?
Isnt That Loud And Dont Think Its Causing Any Problems But Still It Can Be Heard.. LoL...
Yeh Its Not The Actual Pedal Its Self But Some Rubber Black Pipe That Looks Like Its Squeeky? Might Have To Get Some WD40 And Have A Little Spraychris gti wrote:My clutch pedal was squeaky once aswell but it didnt sound like the engine as you say. I told the mechanic when in for sevice and he greased it up and that solved it
Don't use WD40 on anything apart from trying to loosen nuts and bolts or dispelling dampness it is bad stuff for anything else. It displaces moisture and attracts dust big stlye and this ultimately will cause the rustbug.
Use spray grease making sure that you don't get it on any of the pedals and use only a little as it goes along way.
