SLIPPING CLUTCH?
jacko_b_23
SLIPPING CLUTCH?
Post by jacko_b_23 »
I noticed on the motorway in the week somethign strange with the revs in my 2000 polo gti
Seems only to happen over 3000rpm, for example when im cruising at 70mph about 3000rpm, if i boot the gas to overtake the revs shoot up but with very little increase in speed but if i feed the gas in the revs and speed climb like normal. im one to feed the power in anyway but im wondering if there are signs of the clutch slipping?
any help would be appreciated
cheers
Jack
6N2 GTI 00
Re: SLIPPING CLUTCH?
Post by 6N2 GTI 00 »
It does have the symptoms of clutch slipping, but I would expect it to do that in every gear.
Do you know when the clutch was last replaced? if it does need changing then your best going for the uprated SACH clutch.
Does it slip when you put your foot down in 1st, 2nd, 3rd or 4th?
Ben
jacko_b_23
yes it does but only when driving it hard...but getting up to speed on motorways etc there is no problem. just happens if i stab the throttle. havent looked through the records in detail yet, i was going to take it for a service and oil and filter change and also a cam belt if it needs it.
ill look into those clutches though, ill get it looked at in the service. best sort it now rathe than later.
thanks for your help
Jack
6N2 GTI 00
jacko_b_23 wrote:yes it does but only when driving it hard...but getting up to speed on motorways etc there is no problem. just happens if i stab the throttle. havent looked through the records in detail yet, i was going to take it for a service and oil and filter change and also a cam belt if it needs it.
Jack
No problem mate, sounds like it will be your clutch then.
Yeah make sure you check the cambelt history, thats a MUST on the Polo GTI.
I paid the price for not checking mine and the tensioners failed. That's a very costly fix
Hope you get it all sorted
Ben
wheelmanwayne
Post by wheelmanwayne »
mine is doing the same mate and its defo the clutch I can smell it burning when i hit the 120mph mark
jacko_b_23
holla...im going for an oil an filter change tomorrow so ill get boss man to assess the situation, though i want to get the cam belt done too which i think is more important. no burning yet so i reckon i can afford to wait a while til i shell out for a clutch replacement.
you fellas got any reccommendations clutch-wise?
Tim_GTi
Post Whore
Post by Tim_GTi »
SACHs kit, hands down best. GSF can get hold of it, give them a ring though as they don't necessarily have it on the shelf.
a SACHs kit is about £100.
jacko_b_23
nice one thanks, theres a gsf round the block so ill be in there on payday i reckon!
jacko_b_23
belated reply i know, anyways, couldnt get hold of a SACHs one so stuck an LUK clutch in instead an ive got to say has made the world of difference and the daily commute to uni so much easier!
S.Kayani
Post by S.Kayani »
had the exact same problem with mine, went to see mr clutch, fitted a new clutch with 2 year (parts an labour warranty) for £180...now its sorted :D
jacko_b_23
whaa £180! great price! i ended up paying about £250 parts and labour but as well as the clutch getting done I had to get new gearbox oil seals fitted, cuz the one fitted to the recon 'box was a bit damaged and was actually leaking small amounts of oil and some got on the clutch so no wonder it was slipping!
think the original clutch couldve just been cleaned up a bit and worked ok, but i stuck a new one in anyway...peace of mind
S.Kayani
Post by S.Kayani »
yeah, cant go wrong really, just got a quote online, printed it off an went to see em, they even changed a broken nose cone or sumat i had, that was like £3 lol
