I am considering buying an amp and sub sometime soon, but would like to know the ins and outs of installing it properly.
My question is how do you mount both these items? Do you need to drill into the boot floor, or can they be velcroed?
I've got a Mrk 3 Coupe if that helps in any way shape or form.
Whats the best way to mount a sub and amp?
Karl_CLCoupe
- Platinum Member
simon pope
Karl_CLCoupe
- Platinum Member
How do you manage to take out the spare wheel in an emergency with all those wires then?simon pope wrote:i placed a bit of mdf under the carpet then place the box where i though was the best suited, i have used some L shaped brackets and screwed the box to the wood, also screwed the amp to the floor hiding all wires under the carpet in the spare wheel
simon pope
Karl_CLCoupe
- Platinum Member
Karl_CLCoupe wrote:You will be hard pushed, unles you can buy an active subwoofer, with the amp built in that will fit in the recess.kapur wrote:IS it possible to get a sub + an amp in da place of da spare wheel? i might do that!!!
Or maybe go wild and use the recess as the 'box' for the sub...
Karl
How many diff. subs r their? ACTIVE? is dat ne gud?
lol! am kinda a beginner/novice!!!
Also, the recess? wat the hell is that?
sorry for bein such a newbie! lol
Karl_CLCoupe
- Platinum Member
No worries, I'm no expert. Amazing what u can pick up from the guys in Halfords...
Right, from what I was told there are standard subs which you have to hook up to an individual amp (advantages are you can pair the sub and amp according to your needs and preferences. With an ordinary sub you will have to construct your own enclosure 'box' for it (alternatively you can buy one if you don't want the hassle).
The disadvantages to pairing up your own sub and amp are that they may not work well together (this is a rarety (sp?)), and they can be slower to respond to the inputs (but only marginally slower).
You then have 'Active' Subs which are usually the enclosure 'box' for the sub, the sub and the amp. These are great if you don't want to be doing too much wiring, as the sub and amp are pre wired together. All you have to do is hook it up to your headunit. These are slightly quicker to respond, and the sub and amp are usually designed to compliment each other.
There are also 'Active' Bass tubes (essentially the same as an Active Subwoofer.
You then have the different sub sizes:
If you select a small sub (say 10") then it will be quicker to respond to inputs than a large sub (say 15"). These subs may not be as loud as their bigger counterparts, but are more suited to fast paced music (dance, hiphop, R & B and all the other stuff I don't listen to...). However, if you are looking for volume from the Sub, then a big 15" subwoofer is the one for you, slower to respond, but can make a right noise
Most commonly people go for 12" subs, as they suite a broader variety of music.
As for the recess Iwas referrring to, I just mean the recess the spare wheel sat in. Sorry if that wasn't clear.
Karl.
Karl.
