hi all at the last count i had the handbrake light (flashing and beeping), abs, seatbelt lights and the epc on the dash whilst driving.
does it mean these are all faulty or do they simply need to be reset using vagcom?
e.g. brakes are very good, stop very good in the rain yyet the abs light is on?
does a fault really mean a fault
Re: does a fault really mean a fault
If you get that many errors up, i strongly suggest plugging it into vagcom to check it out even if there isnt a fault
- Gary Gee
rapid_f1 wrote:hi all at the last count i had the handbrake light (flashing and beeping), abs, seatbelt lights and the epc on the dash whilst driving.
is the hand brake one flashes does that not mean you fluid is low in you brakes? and EPC is something to do with your pedal box am sure mine came on the other week.. then went off again
