anyone lookin for a...
DanW
Post by DanW »
GT close ratio gearbox or tacho/rev counter?
Need to shift em asap due to space and stuff :roll:
http://www.tigerstyle.co.uk/poloforum/v ... php?t=5195
http://www.tigerstyle.co.uk/poloforum/v ... php?t=5194
Tahrey1043
Post by Tahrey1043 »
to be a pointlessly technical mo'fo....
is that the CEH that gives you 18.2mph/1000 in top, or the slightly higher diff'ed AHD that gives 18.5mph/1000 but with the same ratio "spread"?
because... well... yknow... it makes a whole 2mph difference on the redline, if you were to ever get there :D :D :D muhahaha
DanW
Post by DanW »
ru refering to either 4+ E ? It's not htat one. I'll have to check the code on the box 4u...
Tahrey1043
naw mate im not "looking" as it were :)
i got the GT specs down, just theres two very similar gearboxes, probably dependent on whether you had one size of tyres or the other... the "internal" gearing is all the same but there's a mysterious 2% difference on the differential.
was just trying to spoof you into clambering around under the car :twisted:
(forget it :D)
